15 years agosw+hw EPCS programming using Programmer / nios2-flash-programmer
Hi, I'm again facing a curious episode. I have a system that consists of a fpga with a nios processor (included a epcs controller) + epcs + external sram + external cfi flash. Currently I'm...
15 years ago --- Quote Start --- After programming with the programmer (using the jic file), the fpga don't start, but after turn off/turn on the power supply used with the system, the fpga load the content recently programmed in the epcs and starts sucessfully. --- Quote End --- Try check "Configure device after programming" or same option in Quartus Programmer. To flash sw and hw I use Nios Flash Programmer, it works perfectly. But hw desing should be previously downloaded to device. I prefer sof file instead of jic, no need to convert to jic.
