17 years agoSW loading to ECPS flash issue
Hi everyone, I'm trying to program SW ELF image into ECPS flash - but not in the default manner, meaning not directly after HW image. I've read that it is posibble in the CFI image using ELF2F...
17 years agoOn the EPCS side of things, you could use elf2flash to generate a zero offset flash file and then move it wherever you'd like using objcopy (or nios2-elf-objcopy) with the --change-addresses option.
On the bootloader side of things, you would have to at minimum change how the default bootloader functions. You have sources, so this shouldn't be too difficult. Good luck! - slacker
