21 years agoSustained 100BaseT transfer speeds w/ uClinux 1.4
Hi, I'm interested in hearing from anyone that has made any timing measurements for a sustained data transfer over 100BaseT Ethernet when using the SMSC LAN91C111 I.C. that is installed on ...
21 years agoHave you tried reading you CF card with an USB reader connected to PC and see how fast it can read it?
(make sure you try with a high-speed USB read of course ;o) Done some projects with CF cards a while ago but with mcf5272@66MHz under uClinux-2.4.20 and got some 1 - 2MBytes/secs if I remember correctly. Are you really fixed with the NIOS board and SMSC91C111? SMSC just brought out new chips with better throughput and also supporting 16/32 bit interfaces... And...if you only want to send files from CF card to PC...why do you need to run on uClinux? How about embedded TFTP server? rick
