15 years agoSurprised to get "converted into an equivalent circuit" warning
Hi Folks- I have a Verlog delay line module that seems straightforward and seems to work when I simulate it using ModelSim and when realized on my Cyclone II FPGA. I always get warning 13310 f...
15 years ago --- Quote Start --- i think the power-up values from the initial block disagree with the values from your reset, causing the latch. this is why changing the reset values from adc_data to 0 fixes the issue --- Quote End --- Thanks. That was the key to making the warnings go away. I'm amazed at the deductions that Quartus is making when it analyzes the HDL code. I wonder if it ever misses the intent. My inexperience is obviously exposed. It's such a complex tool and there is clearly no substitute for experience and knowledge. I hope to acquire both over the years. Thanks to everyone for your opinions and help. JJS
