15 years agoSupporting multiple SYSPTFs sanity check
I'm finding myself supporting multiple projects with different SYSPTFs since the NiosII and uClinux is so slick.
I just want to make sure I've figured out how to BEST do this: This is what I'm thinking I should do: 1. When I do a "make menuconfig" under "General Setup" [*] Initial RAM filesystem and RAM disk (initramfs/initrd) support (../romfsFDR ../vendors/Altera/nios2/romfs_list) Initramfs source file(s) I create a new "romfs" directory with a different name and put the corresponding directories there. (here - romfsFDR 2. When I save the configuration I save it as an alternate name. I can also create a different "romfs_list" name And I just have to keep track of my zImage. Is that reasonable? Did I miss anything? Thanks in advance.2 Replies
For multiple projects you can use multiple directories below "vendor". "make menuconfig" allows to select them.
-Michael - Altera_Forum
Thanks !! I missed that. Seems obvious now.
