11 years agoSupport PCIe with Nios
Hello, Is there a software example how to work with PCIe in nios. I did not find in HAL sources and mention of PCIe. Is it supported as a device driver ? I also did not see any mention of ...
11 years agoI don't think you'll find that sort of thing in the HAL sources. You might try u-boot for Nios II (as a start). Have a look at the following post for further information:
http://www.alteraforum.com/forum/showthread.php?t=39015 If you're looking for a PCIe endpoint case, have a look here: http://www.alteraforum.com/forum/showthread.php?t=34392 In the latter case, Nios II need not be involved, but it could certainly help... Cheers! Ura
