Rezef
3 years agoSuggestions on effectively learning NIOSII Soft programing
Guys, I am planning to implement the SD card music player as demonstrated in the example of Altera de-2 115 version. In the example I noticed that I have to use NIOS 2 programing for establishing the...
- 3 years ago
For starters, you can quickly run through any of the booting methods that your board can perform:
Choose boot from OCRAM for example:
Go through the steps up until the "Programming" part.
For learning, you can go through the document as a whole.
EBERLAZARE_I_Intel
3 years agoHi,
The "alt_busy_sleep"; Microsecond delay routine which uses a calibrated busy loop to perform the delay. This is used to implement usleep for both uC/OS-II and the standalone HAL. I'll say it is quite common usage for Nios II designs.
Do you have any issues or have any other questions?
