Rezef
3 years agoSuggestions on effectively learning NIOSII Soft programing
Guys, I am planning to implement the SD card music player as demonstrated in the example of Altera de-2 115 version. In the example I noticed that I have to use NIOS 2 programing for establishing the...
- 3 years ago
For starters, you can quickly run through any of the booting methods that your board can perform:
Choose boot from OCRAM for example:
Go through the steps up until the "Programming" part.
For learning, you can go through the document as a whole.
Rezef
3 years agoI think I have managed to grasp it now, It's essentially adding the Enable bit and RS and RW with the bitwise OR Operation along with the commands and data
