Rezef
3 years agoSuggestions on effectively learning NIOSII Soft programing
Guys, I am planning to implement the SD card music player as demonstrated in the example of Altera de-2 115 version. In the example I noticed that I have to use NIOS 2 programing for establishing the...
- 3 years ago
For starters, you can quickly run through any of the booting methods that your board can perform:
Choose boot from OCRAM for example:
Go through the steps up until the "Programming" part.
For learning, you can go through the document as a whole.
EBERLAZARE_I_Intel
3 years agoHi,
Do you have the full example code/ example design?
From my knowledge, the PIO macros are defined in "altera_avalon_pio_regs.h". The macro "IOWR_ALTERA_AVALON_PIO_DATA" writes the output port.
