Stuck at "Starting Kernel..."
Hey,
I am trying to get a modified version of the GHRD-HPS running on my Arrow sockit board. Here is my setup:- Arrow Sockit Board with Cyclone V
- Ubuntu Core (https://rocketboards.org/foswiki/view/documentation/ubuntucoreforsocfpgaarrowsockit)
- The .rbf file seems to be read correct
- I created and changed all the necessary files (preloader, uboot,...)
U-Boot SPL 2013.01.01 (May 04 2016 - 00:41:22)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 400000 KHz
RESET: COLD
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 1024 MiB
ALTERA DWMMC: 0
reading u-boot.img
reading u-boot.img
U-Boot 2013.01.01 (May 03 2016 - 18:49:51)
CPU : Altera SOCFPGA Platform
I2C: ready
DRAM: 1 GiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
reading u-boot.scr
254 bytes read in 3 ms (82 KiB/s)# # Executing script at 02000000
reading output_files/RGBPatternGen.rbf
2762608 bytes read in 133 ms (19.8 MiB/s)# # Starting application at 0x3FF79544 ...# # Application terminated, rc = 0x0
reading zImage
3465776 bytes read in 161 ms (20.5 MiB/s)
reading PatternGenSystem.dtb
23293 bytes read in 7 ms (3.2 MiB/s)# # Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x00000100
Loading Device Tree to 03ff7000, end 03fffafc ... OK
Starting kernel ...
I managed to get a bit further by changing the order of the sopc2dts --board options ( first hps_common_board_info.xml and then the sockit info)
However linux is still not really booting correctly :(lcd_load_custom_fonts: i2c_master_send returns -121 lcd_cmd_no_params: i2c_master_send returns -121 lcd_cmd_one_param: i2c_master_send returns -121 lcd_cmd_no_params: i2c_master_send returns -121 lcd-comm 0-0028: LCD driver initialized ... ------------------------ WARNING: at fs/sysfs/dir.c:530 sysfs_add_one+0xac/0xbc() sysfs: cannot create duplicate filename '/class/spi_master/spi0' Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.31-ltsi-05151-gc8b20a4# 1 (unwind_backtrace+0x0/0xf8) from (show_stack+0x20/0x24) (show_stack+0x20/0x24) from (dump_stack+0x24/0x28) (dump_stack+0x24/0x28) from (warn_slowpath_common+0x64/0x7c) (warn_slowpath_common+0x64/0x7c) from (warn_slowpath_fmt+0x40/0x48) (warn_slowpath_fmt+0x40/0x48) from (sysfs_add_one+0xac/0xbc) (sysfs_add_one+0xac/0xbc) from (sysfs_do_create_link_sd+0x10c/0x21c) (sysfs_do_create_link_sd+0x10c/0x21c) from (sysfs_create_link+0x30/0x48) (sysfs_create_link+0x30/0x48) from (device_add+0x300/0x5d4) (device_add+0x300/0x5d4) from (spi_register_master+0x150/0x5d4) (spi_register_master+0x150/0x5d4) from (dw_spi_add_host+0x254/0x314) (dw_spi_add_host+0x254/0x314) from (dw_spi_mmio_probe+0x268/0x29c) (dw_spi_mmio_probe+0x268/0x29c) from (platform_drv_probe+0x28/0x2c) (platform_drv_probe+0x28/0x2c) from (really_probe+0x78/0x218) (really_probe+0x78/0x218) from (__driver_attach+0xa8/0xac) (__driver_attach+0xa8/0xac) from (bus_for_each_dev+0x7c/0xb0) (bus_for_each_dev+0x7c/0xb0) from (driver_attach+0x2c/0x30) (driver_attach+0x2c/0x30) from (bus_add_driver+0x1d4/0x260) (bus_add_driver+0x1d4/0x260) from (driver_register+0x88/0x150) (driver_register+0x88/0x150) from (platform_driver_register+0x60/0x68) (platform_driver_register+0x60/0x68) from (dw_spi_mmio_driver_init+0x18/0x1c) (dw_spi_mmio_driver_init+0x18/0x1c) from (do_one_initcall+0x114/0x174) (do_one_initcall+0x114/0x174) from (kernel_init_freeable+0x1ac/0x250) (kernel_init_freeable+0x1ac/0x250) from (kernel_init+0x1c/0x164) (kernel_init+0x1c/0x164) from (ret_from_fork+0x14/0x20) ------ spi_master spi0: problem registering spi master ------------------------ WARNING: at kernel/irq/manage.c:1249 __free_irq+0xb0/0x1d0() Trying to free already-free IRQ 187 Modules linked in: CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.31-ltsi-05151-gc8b20a4# 1 (unwind_backtrace+0x0/0xf8) from (show_stack+0x20/0x24) (show_stack+0x20/0x24) from (dump_stack+0x24/0x28) (dump_stack+0x24/0x28) from (warn_slowpath_common+0x64/0x7c) (warn_slowpath_common+0x64/0x7c) from (warn_slowpath_fmt+0x40/0x48) (warn_slowpath_fmt+0x40/0x48) from (__free_irq+0xb0/0x1d0) (__free_irq+0xb0/0x1d0) from (free_irq+0x5c/0xb4) (free_irq+0x5c/0xb4) from (dw_spi_mmio_probe+0x160/0x29c) (dw_spi_mmio_probe+0x160/0x29c) from (platform_drv_probe+0x28/0x2c) (platform_drv_probe+0x28/0x2c) from (really_probe+0x78/0x218) (really_probe+0x78/0x218) from (__driver_attach+0xa8/0xac) (__driver_attach+0xa8/0xac) from (bus_for_each_dev+0x7c/0xb0) (bus_for_each_dev+0x7c/0xb0) from (driver_attach+0x2c/0x30) (driver_attach+0x2c/0x30) from (bus_add_driver+0x1d4/0x260) (bus_add_driver+0x1d4/0x260) from (driver_register+0x88/0x150) (driver_register+0x88/0x150) from (platform_driver_register+0x60/0x68) (platform_driver_register+0x60/0x68) from (dw_spi_mmio_driver_init+0x18/0x1c) (dw_spi_mmio_driver_init+0x18/0x1c) from (do_one_initcall+0x114/0x174) (do_one_initcall+0x114/0x174) from (kernel_init_freeable+0x1ac/0x250) (kernel_init_freeable+0x1ac/0x250) from (kernel_init+0x1c/0x164) (kernel_init+0x1c/0x164) from (ret_from_fork+0x14/0x20) ------ dw_spi_mmio: probe of fff01000.spi failed with error -17 ... rtc-ds1307: probe of 0-0068 failed with error -5 i2c /dev entries driver dw_wdt: probe of ffd03000.timer failed with error -16 Synopsys Designware Multimedia Card Interface Driver dwmmc_socfpga ff704000.flash: Using internal DMA controller. dwmmc_socfpga ff704000.flash: Version ID is 240a dwmmc_socfpga ff704000.flash: DW MMC controller at irq 171, 32 bit host data width, 1024 deep fifo mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63) dwmmc_socfpga ff704000.flash: 1 slots initialized platform leds.1: Driver leds-gpio requests probe deferral ledtrig-cpu: registered to indicate activity on CPUs usbcore: registered new interface driver usbhid usbhid: USB HID core driver oprofile: using arm/armv7-ca9 ... EXT3-fs (mmcblk0p2): using internal journal EXT3-fs (mmcblk0p2): recovery complete EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode VFS: Mounted root (ext3 filesystem) on device 179:2. devtmpfs: mounted Freeing unused kernel memory: 332K (8067c000 - 806cf000) Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory Unable to handle kernel paging request at virtual address c08d600c pgd = 80004000 *pgd=3f816811, *pte=00000000, *ppte=00000000 Internal error: Oops: 807 SMP ARM Modules linked in: CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 3.10.31-ltsi-05151-gc8b20a4# 1 task: 806db8c0 ti: 806d0000 task.ti: 806d0000 PC is at dw_wdt_ping+0x74/0xa0 LR is at l2x0_cache_sync+0x50/0x54 pc : lr : psr: 600d0113 sp : 806d1dc0 ip : 806d1da8 fp : 806d1dd4 r10: 00000000 r9 : 8070b028 r8 : 803819ec r7 : 00000100 r6 : 806d0018 r5 : 806d20c0 r4 : 807407e4 r3 : c08d6000 r2 : 00000076 r1 : a00d0113 r0 : 8070ce04 Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel Control: 10c5387d Table: 3fb8004a DAC: 00000015 Process swapper/0 (pid: 0, stack limit = 0x806d0240) Stack: (0x806d1dc0 to 0x806d2000) 1dc0: 80712240 807407f8 806d1e0c 806d1dd8 800320cc 803819f8 9f24f780 00000000 1de0: 80f5c648 80712240 807407f8 806d2084 00000000 806d1e20 803819ec 00000000 1e00: 806d1e54 806d1e10 80033598 80032088 80712a54 806d20c0 00200200 8070b028 1e20: 806d1e20 806d1e20 806cd568 00000001 00000001 806d2084 00000004 806d83e8 1e40: 00000100 806d0018 806d1ebc 806d1e58 8002be68 800333c0 9e8c665a 00000000 1e60: 9e8c665a 00200000 8070ae52 806d20c0 ffff8bdb 806ddbec 0000000a 80712080 1e80: 806cd6e0 00000000 00000004 8070afc4 80014d88 600d0193 0000001d 00000000 1ea0: fee00100 806d83e8 806d843c 00000000 806d1ed4 806d1ec0 8002c098 8002bd48 1ec0: 806ced9c 0000001d 806d1eec 806d1ed8 8002c320 8002c044 806ced9c 0000001d 1ee0: 806d1f0c 806d1ef0 8000f660 8002c2c0 fee0010c 806d8e70 806d1f30 fee00100 1f00: 806d1f2c 806d1f10 80008564 8000f618 8000fa80 600d0013 ffffffff 806d1f64 1f20: 806d1f84 806d1f30 8000e280 80008534 80f5c7f8 00000000 00000966 00000000 1f40: 806d0000 806d0008 806d0000 8070b410 806d83e8 806d843c 00000000 806d1f84 1f60: 806d1f88 806d1f78 8000fa7c 8000fa80 600d0013 ffffffff 806d1fa4 806d1f88 1f80: 80060b14 8000fa50 8070ae36 804c9ee0 804c62c0 806b3cf0 806d1fb4 806d1fa8 1fa0: 804bd1b0 800609d8 806d1ff4 806d1fb8 8067cab4 804bd138 ffffffff ffffffff 1fc0: 8067c5a0 00000000 00000000 806b3cf0 10c5387d 806d83b4 806b3cec 806dc6d4 1fe0: 0000406a 413fc090 00000000 806d1ff8 00008074 8067c80c 00000000 00000000 (dw_wdt_ping+0x74/0xa0) from (call_timer_fn+0x50/0x120) (call_timer_fn+0x50/0x120) from (run_timer_softirq+0x1e4/0x298) (run_timer_softirq+0x1e4/0x298) from (__do_softirq+0x12c/0x290) (__do_softirq+0x12c/0x290) from (do_softirq+0x60/0x68) (do_softirq+0x60/0x68) from (irq_exit+0x6c/0xa4) (irq_exit+0x6c/0xa4) from (handle_IRQ+0x54/0xa0) (handle_IRQ+0x54/0xa0) from (gic_handle_irq+0x3c/0x6c) (gic_handle_irq+0x3c/0x6c) from (__irq_svc+0x40/0x50) Exception stack(0x806d1f30 to 0x806d1f78) 1f20: 80f5c7f8 00000000 00000966 00000000 1f40: 806d0000 806d0008 806d0000 8070b410 806d83e8 806d843c 00000000 806d1f84 1f60: 806d1f88 806d1f78 8000fa7c 8000fa80 600d0013 ffffffff (__irq_svc+0x40/0x50) from (arch_cpu_idle+0x3c/0x40) (arch_cpu_idle+0x3c/0x40) from (cpu_startup_entry+0x148/0x218) (cpu_startup_entry+0x148/0x218) from (rest_init+0x84/0x88) (rest_init+0x84/0x88) from (start_kernel+0x2b4/0x2c0) Code: 0a000000 e12fff33 e5943004 e3a02076 (e583200c) ------ - Altera_Forum
I had exactly the same problem a few weeks ago, apparently the provided .xml contained errors.
Look in hps_common_board_info.xml and replace all DTappend by DTAppend In soc_system_board_info.xml, remove the > at line 22. Personally I created the .dtb with sopc2dts in command lines with cygdrive env. - Altera_Forum
Thanks for the tip, however the DTappend was already correct for my version.
Could you tell me in which order you passed the .xml files to sopc2dts? I am not sure if i am doing it correct. - Altera_Forum
I follow the tutorial at : https://rocketboards.org/foswiki/view/documentation/gsrd140devicetreegenerator
Under cygwin environment : $ sopc2dts --input soc_system.sopcinfo --output socfpga.dtb --type dtb --board soc_system_board_info.xml --board hps_common_board_info.xml --bridge-removal all --clocks - Altera_Forum
I ran into a similar problem and I ended up taking the angstrom-socfpga (Yocto) release, built the entire image and then started tinkering with the device tree. I never had much luck in porting the Qsys tree to DTB, especially with custom logic attached to the HPS. For me taking the home-build standard using cyclone5-defconfig, or something like that, and modify it to fit your new design works best. I remember having problems with Watchdog timers that where put in the device tree by the sopc2dts tool but were actually lacking in h/w causing trace dumps just like yours.
