10 years agoStuck at "Starting Kernel..."
Hey, I am trying to get a modified version of the GHRD-HPS running on my Arrow sockit board. Here is my setup: Arrow Sockit Board with Cyclone V Ubuntu Core (https://rocketboards.org...
10 years agoI managed to get a bit further by changing the order of the sopc2dts --board options ( first hps_common_board_info.xml and then the sockit info)
However linux is still not really booting correctly :(
lcd_load_custom_fonts: i2c_master_send returns -121
lcd_cmd_no_params: i2c_master_send returns -121
lcd_cmd_one_param: i2c_master_send returns -121
lcd-comm 0-0028: LCD driver initialized
WARNING: at fs/sysfs/dir.c:530 sysfs_add_one+0xac/0xbc()
sysfs: cannot create duplicate filename '/class/spi_master/spi0'
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.31-ltsi-05151-gc8b20a4# 1
(unwind_backtrace+0x0/0xf8) from (show_stack+0x20/0x24)
(show_stack+0x20/0x24) from (dump_stack+0x24/0x28)
(dump_stack+0x24/0x28) from (warn_slowpath_common+0x64/0x7c)
(warn_slowpath_common+0x64/0x7c) from (warn_slowpath_fmt+0x40/0x48)
(warn_slowpath_fmt+0x40/0x48) from (sysfs_add_one+0xac/0xbc)
(sysfs_add_one+0xac/0xbc) from (sysfs_do_create_link_sd+0x10c/0x21c)
(sysfs_do_create_link_sd+0x10c/0x21c) from (sysfs_create_link+0x30/0x48)
(sysfs_create_link+0x30/0x48) from (device_add+0x300/0x5d4)
(device_add+0x300/0x5d4) from (spi_register_master+0x150/0x5d4)
(spi_register_master+0x150/0x5d4) from (dw_spi_add_host+0x254/0x314)
(dw_spi_add_host+0x254/0x314) from (dw_spi_mmio_probe+0x268/0x29c)
(dw_spi_mmio_probe+0x268/0x29c) from (platform_drv_probe+0x28/0x2c)
(platform_drv_probe+0x28/0x2c) from (really_probe+0x78/0x218)
(really_probe+0x78/0x218) from (__driver_attach+0xa8/0xac)
(__driver_attach+0xa8/0xac) from (bus_for_each_dev+0x7c/0xb0)
(bus_for_each_dev+0x7c/0xb0) from (driver_attach+0x2c/0x30)
(driver_attach+0x2c/0x30) from (bus_add_driver+0x1d4/0x260)
(bus_add_driver+0x1d4/0x260) from (driver_register+0x88/0x150)
(driver_register+0x88/0x150) from (platform_driver_register+0x60/0x68)
(platform_driver_register+0x60/0x68) from (dw_spi_mmio_driver_init+0x18/0x1c)
(dw_spi_mmio_driver_init+0x18/0x1c) from (do_one_initcall+0x114/0x174)
(do_one_initcall+0x114/0x174) from (kernel_init_freeable+0x1ac/0x250)
(kernel_init_freeable+0x1ac/0x250) from (kernel_init+0x1c/0x164)
(kernel_init+0x1c/0x164) from (ret_from_fork+0x14/0x20)
spi_master spi0: problem registering spi master
WARNING: at kernel/irq/manage.c:1249 __free_irq+0xb0/0x1d0()
Trying to free already-free IRQ 187
Modules linked in:
CPU: 0 PID: 1 Comm: swapper/0 Tainted: G W 3.10.31-ltsi-05151-gc8b20a4# 1
(warn_slowpath_fmt+0x40/0x48) from (__free_irq+0xb0/0x1d0)
(__free_irq+0xb0/0x1d0) from (free_irq+0x5c/0xb4)
(free_irq+0x5c/0xb4) from (dw_spi_mmio_probe+0x160/0x29c)
(dw_spi_mmio_probe+0x160/0x29c) from (platform_drv_probe+0x28/0x2c)
dw_spi_mmio: probe of fff01000.spi failed with error -17
rtc-ds1307: probe of 0-0068 failed with error -5
i2c /dev entries driver
dw_wdt: probe of ffd03000.timer failed with error -16
Synopsys Designware Multimedia Card Interface Driver
dwmmc_socfpga ff704000.flash: Using internal DMA controller.
dwmmc_socfpga ff704000.flash: Version ID is 240a
dwmmc_socfpga ff704000.flash: DW MMC controller at irq 171, 32 bit host data width, 1024 deep fifo
mmc_host mmc0: Bus speed (slot 0) = 50000000Hz (slot req 400000Hz, actual 396825HZ div = 63)
dwmmc_socfpga ff704000.flash: 1 slots initialized
platform leds.1: Driver leds-gpio requests probe deferral
ledtrig-cpu: registered to indicate activity on CPUs
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
oprofile: using arm/armv7-ca9
EXT3-fs (mmcblk0p2): using internal journal
EXT3-fs (mmcblk0p2): recovery complete
EXT3-fs (mmcblk0p2): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 332K (8067c000 - 806cf000)
Mount failed for selinuxfs on /sys/fs/selinux: No such file or directory
Unable to handle kernel paging request at virtual address c08d600c
pgd = 80004000
*pgd=3f816811, *pte=00000000, *ppte=00000000
Internal error: Oops: 807 SMP ARM
Modules linked in:
CPU: 0 PID: 0 Comm: swapper/0 Tainted: G W 3.10.31-ltsi-05151-gc8b20a4# 1
task: 806db8c0 ti: 806d0000 task.ti: 806d0000
PC is at dw_wdt_ping+0x74/0xa0
LR is at l2x0_cache_sync+0x50/0x54
pc : lr : psr: 600d0113
sp : 806d1dc0 ip : 806d1da8 fp : 806d1dd4
r10: 00000000 r9 : 8070b028 r8 : 803819ec
r7 : 00000100 r6 : 806d0018 r5 : 806d20c0 r4 : 807407e4
r3 : c08d6000 r2 : 00000076 r1 : a00d0113 r0 : 8070ce04
Flags: nZCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment kernel
Control: 10c5387d Table: 3fb8004a DAC: 00000015
Process swapper/0 (pid: 0, stack limit = 0x806d0240)
Stack: (0x806d1dc0 to 0x806d2000)
1dc0: 80712240 807407f8 806d1e0c 806d1dd8 800320cc 803819f8 9f24f780 00000000
1de0: 80f5c648 80712240 807407f8 806d2084 00000000 806d1e20 803819ec 00000000
1e00: 806d1e54 806d1e10 80033598 80032088 80712a54 806d20c0 00200200 8070b028
1e20: 806d1e20 806d1e20 806cd568 00000001 00000001 806d2084 00000004 806d83e8
1e40: 00000100 806d0018 806d1ebc 806d1e58 8002be68 800333c0 9e8c665a 00000000
1e60: 9e8c665a 00200000 8070ae52 806d20c0 ffff8bdb 806ddbec 0000000a 80712080
1e80: 806cd6e0 00000000 00000004 8070afc4 80014d88 600d0193 0000001d 00000000
1ea0: fee00100 806d83e8 806d843c 00000000 806d1ed4 806d1ec0 8002c098 8002bd48
1ec0: 806ced9c 0000001d 806d1eec 806d1ed8 8002c320 8002c044 806ced9c 0000001d
1ee0: 806d1f0c 806d1ef0 8000f660 8002c2c0 fee0010c 806d8e70 806d1f30 fee00100
1f00: 806d1f2c 806d1f10 80008564 8000f618 8000fa80 600d0013 ffffffff 806d1f64
1f20: 806d1f84 806d1f30 8000e280 80008534 80f5c7f8 00000000 00000966 00000000
1f40: 806d0000 806d0008 806d0000 8070b410 806d83e8 806d843c 00000000 806d1f84
1f60: 806d1f88 806d1f78 8000fa7c 8000fa80 600d0013 ffffffff 806d1fa4 806d1f88
1f80: 80060b14 8000fa50 8070ae36 804c9ee0 804c62c0 806b3cf0 806d1fb4 806d1fa8
1fa0: 804bd1b0 800609d8 806d1ff4 806d1fb8 8067cab4 804bd138 ffffffff ffffffff
1fc0: 8067c5a0 00000000 00000000 806b3cf0 10c5387d 806d83b4 806b3cec 806dc6d4
1fe0: 0000406a 413fc090 00000000 806d1ff8 00008074 8067c80c 00000000 00000000
(dw_wdt_ping+0x74/0xa0) from (call_timer_fn+0x50/0x120)
(call_timer_fn+0x50/0x120) from (run_timer_softirq+0x1e4/0x298)
(run_timer_softirq+0x1e4/0x298) from (__do_softirq+0x12c/0x290)
(__do_softirq+0x12c/0x290) from (do_softirq+0x60/0x68)
(do_softirq+0x60/0x68) from (irq_exit+0x6c/0xa4)
(irq_exit+0x6c/0xa4) from (handle_IRQ+0x54/0xa0)
(handle_IRQ+0x54/0xa0) from (gic_handle_irq+0x3c/0x6c)
(gic_handle_irq+0x3c/0x6c) from (__irq_svc+0x40/0x50)
Exception stack(0x806d1f30 to 0x806d1f78)
1f20: 80f5c7f8 00000000 00000966 00000000
(__irq_svc+0x40/0x50) from (arch_cpu_idle+0x3c/0x40)
(arch_cpu_idle+0x3c/0x40) from (cpu_startup_entry+0x148/0x218)
(cpu_startup_entry+0x148/0x218) from (rest_init+0x84/0x88)
(rest_init+0x84/0x88) from (start_kernel+0x2b4/0x2c0)
Code: 0a000000 e12fff33 e5943004 e3a02076 (e583200c)
