20 years agoStreaming without downloading from network
Hello all once again ... sorry for the continuous headaches i make http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif I'm working on my grad. project .. it's a...
20 years ago --- Quote Start --- originally posted by tarekeldeeb@Jun 30 2006, 12:18 PM but i want to test large streams .. i need to use the network ..
hippo said that the ftp is quite easy ...
but .. as far as i know .. ftp will download the whole file !!
this is not what i want ..at all http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/ohmy.gif
i thought samba shares can be mounted .. and the shared files can be streamed (read) easily .. but .. i felt that the samba in uclinux is not an easy job .. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
can any1 help me ?? ,, any ideas ??
thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=16578)
--- quote end ---
--- Quote End --- What about NFS to a linux machine....all you need is a supercheap PC, load Linux, copy your file to it, setup your NIOS board for NFS, and boot. If you already have a Linux PC you're almost there already. While I don't have much NIOS experience, I have done a lot of other Linux development on embedded platforms and have always utilized NFS mounts. This is much easier than creating a flash image everytime something changes and is meant to work as a mounted FS, so it gets around the FTP issue that you noted. SAMBA is similar, but to act as a connection to Windows FS--which throws many more variables into the mix. Keith
