20 years ago
Streaming without downloading from network
Hello all once again ...
sorry for the continuous headaches i make http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/huh.gif
I&#39;m working on my grad. project .. it&#39;s about video decoding ..
i want to stream a LARGE video file over the network (from my PC) .. decode the stream under uCLinux .. then display the decoded frames(this final step is not yet done)
i tried loading a small video file on the FS ,, as a test.. it works fine..
but i want to test large streams .. i need to use the network ..
Hippo said that the ftp is quite easy ...
but .. as far as I know .. ftp will download the whole file !!
This is not what i want ..at ALL http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif
i thought samba shares can be mounted .. and the shared files can be streamed (read) easily .. but .. i felt that the samba in uClinux is not an easy job .. http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/blink.gif
can any1 help me ?? ,, any ideas ??
Thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
    --- Quote Start ---
    hippo said that the ftp is quite easy ...
    but .. as far as i know .. ftp will download the whole file !!
    this is not what i want ..at all http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/ohmy.gif
    i thought samba shares can be mounted .. and the shared files can be streamed (read) easily .. but .. i felt that the samba in uclinux is not an easy job .. http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/blink.gif
    thanks in advance http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/biggrin.gif
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16578)
    --- quote end ---
    --- Quote End ---
    What about NFS to a linux machine....all you need is a supercheap PC, load Linux, copy your file to it, setup your NIOS board for NFS, and boot. If you already have a Linux PC you&#39;re almost there already.
    While I don&#39;t have much NIOS experience, I have done a lot of other Linux development on embedded platforms and have always utilized NFS mounts. This is much easier than creating a flash image everytime something changes and is meant to work as a mounted FS, so it gets around the FTP issue that you noted. SAMBA is similar, but to act as a connection to Windows FS--which throws many more variables into the mix.
    Keith
    Hi tarekeldeeb,
    > ,, any ideas ??
    You might want to implement a tftp clien in your application. It&#39;s not very difficult, your app can
    control the read requests, and there are plenty of servers you can use on unix and windoze machines.
    --Scott
    --- Quote Start ---
    originally posted by espian@Jun 30 2006, 09:45 PM
    what about nfs to a linux machine....all you need is a supercheap pc, load linux, copy your file to it, setup your nios board for nfs, and boot. if you already have a linux pc you&#39;re almost there already.
    while i don&#39;t have much nios experience, i have done a lot of other linux development on embedded platforms and have always utilized nfs mounts. this is much easier than creating a flash image everytime something changes and is meant to work as a mounted fs, so it gets around the ftp issue that you noted. samba is similar, but to act as a connection to windows fs--which throws many more variables into the mix.
    keith
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16580)
    --- quote end ---
    --- Quote End ---
    Keith .. thanks a lot ..
    can you please tell me how to prepare my linux to act as a server to share on NFS ?? .. also .. will i use " mount " command on the uClinux ..or it needs a seperate client ?? .. pls help .. i feel that i miss many vital concepts http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/sad.gif
    <div class='quotetop'>QUOTE </div>
    --- Quote Start ---
    --Scott[/b]
    --- Quote End ---
    Dear Scott, .. can u please tell me a demo code example (psudo) about that ..
    I will appretiate any kind of help http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/smile.gif
    Thanks guys .. you are really pushing me further .. and forward http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/biggrin.gif
    --- Quote Start ---
    originally posted by tarekeldeeb@Jun 30 2006, 07:37 PM
    keith .. thanks a lot ..
    can you please tell me how to prepare my linux to act as a server to share on nfs ?? .. also .. will i use " mount " command on the uclinux ..or it needs a seperate client ?? .. pls help .. i feel that i miss many vital concepts http://forum.niosforum.com/work2/style_emoticons/<#emo_dir#>/sad.gif
    <div align='right'><{post_snapback}> (index.php?act=findpost&pid=16588)
    --- quote end ---
    --- Quote End ---
    http://www.tldp.org/howto/nfs-howto/index.html (http://www.tldp.org/howto/nfs-howto/index.html)
    I started writing all of this out, but I&#39;m sure this is much more complete.
    Hope this helps.
    Keith
