21 years agoStratix Professional Edition vs Cyclone Edition
What advantages does Stratix Prof Edition have compared with Cyclone Edition? The price of Stratix Prof Edition is much higher. Just because Stratix Prof Edition can achieve a higher DMIPS than C...
21 years agoIt's due to the FPGA populated on the board. The main differences between the two boards are 1) The Stratix part (1s40) on the Pro board is much larger in terms of logic elements and memory resources compared to the Cyclone part (1c20). 2) The Cyclone board has an EPCS device (it's a storage device that you can put your hardware design and software into). Everything else is the same (SRAM, SDR SDRAM, LAN91c111, Flash, Proto headers, etc....)
