21 years agoStratix II Seven Seg Display [RESOLVED]
Hi, Recently, I was able to successfully build, and download, a kernel project to run from RAM on a Nios II Development Kit (Stratix II edition). However, after the download was complete, and ...
21 years agoHello again Ken,
<div class='quotetop'>QUOTE </div> --- Quote Start --- That feature is still enabled by default. Can you take a peek at your configuration? The following option needs to be turned on: Processor type and features -> Enable leds, seven segment display Which hardware design are you using with the kernel?[/b] --- Quote End --- I just checked my 2.6.11 kernel configuration and the "Enable leds, seven segment display" option is not listed under "Processor type and features --->". Does this mean the LED's and seven-segment display should be active all the time or is there something I'm missing? I look forward to your response. Thanks, Brad.
