21 years agoStratix II Seven Seg Display [RESOLVED]
Hi, Recently, I was able to successfully build, and download, a kernel project to run from RAM on a Nios II Development Kit (Stratix II edition). However, after the download was complete, and ...
21 years agoHi ken,
<div class='quotetop'>QUOTE </div> --- Quote Start --- That feature is still enabled by default. Can you take a peek at your configuration? The following option needs to be turned on: Processor type and features -> Enable leds, seven segment display Which hardware design are you using with the kernel?[/b] --- Quote End --- Currently, I'm using the standard.sof design with the 2.6.9 kernel. I used this same hardware design with the 2.6.11 kernel and everything seemed to be fine. I don't think I changed the kernel configuration default that came with v1.4 of the distribution. The only change I made was to ensure that the Altera Stratix II platform was selected. I will check to see if that option got turned off by mistake. Thanks for the info. Brad.
