21 years agoStratix 2 DSP Flash programming
Hi I'm working with a Stratix 2 DSP board. All I want to do is program the configuration data into the flash so it boots up automatically. No need for Nios, but it looks to me as if it...
21 years agoFurther info....
Now I am successfully communicating with the Target controller, but it reports that it cannot communicate with the flash itself. This is not a hardware issue...I can create a "standard" Nios and run a flash test OK. There is some reason I can't use the target together with the Altera-supplied firmware that is supposed to program the flash. Has ANYONE successfully done this on a Stratix 2 DSP board? Is it possible there is something that makes the Altera supplied flash routines not work with the device in this board? Thanks
