19 years agoStrange varible declare!
Hi, everyone
Have you ever met this strange problem? I have use Q2 5.0 and NIOS IDE 5.0 to develope my project. My program is running in CFI flash and my FPGA is EP1C12Q240. A simple program is this: . . float a = 2100; . main() { ...... } This program is running properly. But when I change the variable "a" 's initial value to 10500, the program became this: . . float a = 10500; . main() { ...... } The program DONT RUN!!!. And the program did not optimize. So I have to initialeze the varible in the "main" program: . float a; . main() { a = 10500; ...... } Then the program can run porperly whenever I change the initial value. did you ever met this? ThanksNo RepliesBe the first to reply
