21 years agoStrange value while debugging in Eclipse
All, I encountered a very strange problem while debugging my application (KVM) on NiosII with uclinux from Eclipse. The value of some variable is not correct while showed from the Eclipse, when...
21 years agoSo, what is the workaround you are using now? To rely on the assembly code?
Thanks, Neo
