21 years agoStrange value while debugging in Eclipse
All, I encountered a very strange problem while debugging my application (KVM) on NiosII with uclinux from Eclipse. The value of some variable is not correct while showed from the Eclipse, when...
21 years ago<div class='quotetop'>QUOTE </div>
--- Quote Start --- But some variables have the correct value, such as "argc"[/b] --- Quote End --- argc is different. It is an argument passed in on stack, and that memory location has the valid value as long as the main function does not return. <div class='quotetop'>QUOTE </div> --- Quote Start --- Can I solve this problem if using the gdb directly?[/b] --- Quote End --- no. I have the same problem with gdb. Besides, debuging application using gdb is a very painful manual process right now, better to stick to the GUI.
