21 years agoStrange value while debugging in Eclipse
All, I encountered a very strange problem while debugging my application (KVM) on NiosII with uclinux from Eclipse. The value of some variable is not correct while showed from the Eclipse, when...
21 years agoSo you mean the source code in .C does not match the assembly well? But some variables have the correct value, such as "argc".
Can I solve this problem if using the gdb directly? Could you show me how to debug application by gdb instead of using the GUI? May I debug the application locally by gdb, which I once tried on Linux PowerPC? Thanks, Neo
