16 years agostrange results with IORD IOWR
Hi there,
I've made my custom component with 64bit input vector and 8bit output, successfuly connected to system interconnection fabric. In nios2-ide when I try to send vector to my component using IOWR i get warning:alt_u64 uwektor1=0x17463f8c62ae;
IOWR(SSN_COMPONENT_WE_BASE, 0, uwektor1);I get: --- Quote Start --- warning: integer constant is too large for "long" type --- Quote End --- And then the results read using: result=IORD_8DIRECT( SSN_COMPONENT_WY_BASE, 0 );are strage. Moreover, such a code: IOWR(SSN_COMPONENT_WE_BASE, 0, uwektor1);
printf("0x%X \n",result);
printf("0x%X \n",result);gives me two different results?! --- Quote Start --- 0xFD 0xDD --- Quote End --- (the DD should be correct output) What could cause such a problem? Previously I've made and programmed verion with 16bit input and 8bit output and everything was in order. How should I fix the problem? Thanks in advance for any tips.1 Reply
IORD/WR work with 32-bit values. I don't know what the exact results are when you supply them with 64-bits integers, but it is most probably not what you would expect.
