12 years agoStrange problem when editing .vhd files on Ubuntu
I keep having a strange thing happen when I'm editing .vhd files in quartus ii 64-bit version 13.0.0 build 156 04/24/2013 sj web edition (using this version for Cyclone II support) on ubuntu 13.10 64...
12 years agoMy guess would be that there's not a clean system interfacing on your system (Altera only tests with RHEL and compatible Linuces). My advice would be start re-naming the ".so" files that duplicate system ".so" files that are part of Quartus II and see when and if that solves the issue you're seeing.
I know it's tedious, but I have seen things like this in the past and following this sort of procedure did work for me. Cheers! slacker
