17 years agoStrange alt_flash_open_dev() behavior
I have some strangeness, really I am missing something, that I am having a bit of a problem tracking down. I have a new board, which I would immediately suspect before SW, however, I am able to do a SFL of an image, using a JIC file, AN370. I can actually see the device ID silicon read from the EPCS device. So that leaves me with either something in the SOPC build or the SW. Oh, I forgot, since I am using a tiny CIII, I had to get rid of the stdio.h and use the alt_stdio.h. Now, I just started with the mem_test.c as a template and just stripped it to its bare essentials; Just want to R/W to one block? Here is snippet of code where alt_flash_open is called: *********************************************** if (flash_type == EPCS) { strcpy(flashname, "/dev/epcs_flash_controller_0\0"); //debug alt_printf(" -Flash controller name is: %s\n", flashname); } //ret_code = GetFlashName(flashname, flash_type); fd = alt_flash_open_dev(flashname); ************************************************* Reading thorugh similar alt_flash_open_dev() problems on the forum, I found that the ..open_dev() function calls alt_find_dev() which has a <stdio.h> but just to me atleast seems to use just <string.h> functions. So why am I getting a return of NULL from alt_flash_open_dev()? Can I rule out SW? That would leave me with something in the SOPC builder. First I checked the pins from my compile and saw that they match up with Active Serial. Good. NOTE: Small complaint to ALtera!! When you build a SOPC system with the EPCS flash controller, and then populate a top level with BDF block, a seemingly natural way to build a fast SOPC system, the pins " BECKON" you to connect them to external pins. Maybe I am the only one that had trouble with this small little fact, but do not connect the pins, as the tool already knows where the pins belong. Just a rookie mistake on my part. Anyway, does the SFL use a different peripheral than the EPCS controller. In other words is the ASMI different than the EPCS flash controller? Probably? Aren't both of them just SPI controllers? I know that the ASMI for the SFL load works but not so sure about the EPCS flash controller. Regards3 Replies
For writing and reading in an EPCS flash memory, see on this topic (the mine ^^) : http://forum.niosforum.com/forum/index.php?showtopic=6914 (http://forum.niosforum.com/forum/index.php?showtopic=6914) The ASMI controller is an old version of EPCS I believe. Don't use it if you want to keep compatibility with the next version of QII. - Altera_Forum
Hello mig86,
That link looks very useful. Regards - Altera_Forum
Also, keep in mind that for Cyclone III devices the EPCS related signals are _not_ automagically connected for you. For Cyclone III devices, the epcs_controller does not use ASMI, so you have to hook the pins up yourself at the top level in your design.
[UPDATE: Here's a link (http://www.altera.com/support/kdb/solutions/rd11012007_792.html) to support my point.] Cheers, - slacker
