21 years agoSTL compilation error
Anyone ever seen this one? `__static_initialization_and_destruction_0(int, int)': locale-inst.o(.text+0xa0): global pointer relative address out of range Adding an std::string causes...
21 years agoyes -G0 does solve the problem, http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif
I did try combinations of command line options for linking. but never thought of declearing -G0 on compiler command line. Once again your advice works, you should be admin here. thanks for the advice.
