21 years agoSTL compilation error
Anyone ever seen this one? `__static_initialization_and_destruction_0(int, int)': locale-inst.o(.text+0xa0): global pointer relative address out of range Adding an std::string causes...
21 years agoI know that some of the Altera guys are monitoring this forum, so hopefully something will be done to fix this error. I guess there's a workaround where I juggle the segments myself, but I'd rather that they fixed the issue.
The coders in here that use uLinux - are they using the same compiler as we are? If they are, then they should have the same problem (I guess)
