16 years agostill verify failed with on-chip memory??
Hi, I'm using SratixII 2s60 dev board kit (with two adcs and two dacs on), and I want to run "hello world" in NiosII IDE in debug/release mode. In SOPC I add components of niosIIcore/avalonMMTri...
16 years agoHi
Just verify whether the Nios II ide is taking the correct ptf file or not It should solve the problem Just right click on the project directory and see in the System library properties there you can see the path of the ptf file taken Might the path is wrong regards M Kalyansrinivas
