16 years agostill verify failed with on-chip memory??
Hi, I'm using SratixII 2s60 dev board kit (with two adcs and two dacs on), and I want to run "hello world" in NiosII IDE in debug/release mode. In SOPC I add components of niosIIcore/avalonMMTri...
16 years ago --- Quote Start --- hmm, looks like, the hardware don't even get your program data... have you tried to add a sys_id component to your system - recompile your Quartus Project - programm your FPGA via Quartus Programmer and then rerun the IDE Project. If he says, that the sys_id is wrong - there may be a general problem with your programmer... --- Quote End --- Yes, I got the error, in fact from the beginning, I have searched for the answers and it seems a quit normal problem and don't have an exact explaination or solution. But I get rid of sys_id component and therefore no "sys_id not match" error information produced(of course). Then I run all the codes in on-chip-memory, still not working. Does the programmer sitll check the sys_id "inside (just without error info)" even you do not use sys_id component in sopc?? Is this the Operation system/quartus/sopc/niosIDE software problem rather than board/hardware problem.May be I have to reinstall all the softwares...~~:confused: That's one head scratching thing for large softwares, you never kown where the problem is as it's only a black box for you... :( ---- Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Pausing target processor: not responding. Resetting and trying again: OK Reading System ID at address 0x00000000: ID value does not match: read 0x41FFFD00; expected 0x40D7B500 Timestamp value does not match: image on board is newer than expected Read timestamp 14:00:46 2010/01/02; expected 22:21:58 2009/12/08 The software you are downloading may not run on the system which is currently configured into the device. Please download the correct SOF or recompile. Leaving target processor paused
