21 years agoStill UBoot ing...
Well thanks to everyone one and all my UBoot seems to be up and running fine however I'm still having a little bit of grief getting the final bits working (think I'm gonna write an app note o...
21 years agoHi Scott,
thanks for the speedy reply, here is the objdump blmsimple.elf: file format elf32-littlenios2 Sections: Idx Name Size VMA LMA File off Algn 0 .entry 00000020 00810800 00810800 00000094 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 1 .exceptions 00000248 01000020 01000020 000000b4 2**2 CONTENTS, ALLOC, LOAD, READONLY, CODE 2 .text 000000f0 01000268 01000268 000002fc 2**3 CONTENTS, ALLOC, LOAD, READONLY, CODE 3 .rodata 00000000 01000358 01000358 000003ec 2**0 CONTENTS 4 .rwdata 00000000 01000358 01000358 000003ec 2**0 CONTENTS, ALLOC, LOAD, DATA 5 .bss 00000000 01000358 01000358 000003ec 2**0 ALLOC 6 .ext_flash 00000000 00000000 00000000 000003ec 2**0 CONTENTS 7 .sdram 00000000 01000358 01000358 000003ec 2**0 CONTENTS 8 .epcs_controller 00000000 00810820 00810820 000003ec 2**0 CONTENTS 9 .comment 0000002c 00000000 00000000 000003ec 2**0 CONTENTS, READONLY 10 .debug_aranges 00000068 00000000 00000000 00000418 2**3 CONTENTS, READONLY, DEBUGGING 11 .debug_pubnames 0000001f 00000000 00000000 00000480 2**0 CONTENTS, READONLY, DEBUGGING 12 .debug_info 00000244 00000000 00000000 0000049f 2**0 CONTENTS, READONLY, DEBUGGING 13 .debug_abbrev 0000008a 00000000 00000000 000006e3 2**0 CONTENTS, READONLY, DEBUGGING 14 .debug_line 000002d0 00000000 00000000 0000076d 2**0 CONTENTS, READONLY, DEBUGGING 15 .debug_frame 00000030 00000000 00000000 00000a40 2**2 CONTENTS, READONLY, DEBUGGING 16 .debug_str 000000e9 00000000 00000000 00000a70 2**0 CONTENTS, READONLY, DEBUGGING Now I can see that it is insitisting on sticking entry in the EPCS location (which of course is no good to me since U-boot actually comes from there). so it is almost like I want to omit/strip that bit of code from the elf so that it just loads up at 0x0100_0000 or whatever. Can this be simply done from the NIOS IDE or is it going to take a bit of trickery?
