20 years agostill struggling with toolchain
I tried to build my toolchain following this thread previous thread (http://forum.niosforum.com/forum/index.php?showtopic=3129&st=0) and I did the best I could. But somehow I am still stuck at the busybox. /home/bdu/NIOS/buildroot/build_nios2/staging_dir/bin-ccache/../lib/gcc/nios2-linux-uclibc/3.4.2/../../../../nios2-linux-uclibc/bin/ld: unrecognized option '-z' /home/bdu/NIOS/buildroot/build_nios2/staging_dir/bin-ccache/../lib/gcc/nios2-linux-uclibc/3.4.2/../../../../nios2-linux-uclibc/bin/ld: use the --help option for usage information GNU ld version 2.15 collect2: ld returned 1 exit status make[2]: *** [libbusybox.so.1.1.1] Error 1 make[1]: *** [_all] Error 2 make[1]: Leaving directory `/home/bdu/NIOS/buildroot/build_nios2/busybox' make: *** [/home/bdu/NIOS/buildroot/build_nios2/busybox/busybox] Error 2 The ld does not support -z option. I guess this has something to do with the patches or configs. But I could figure out which part I missed. I'd appreciate any help on this.2 Replies
Hi bdu,
It try to build shared libbb, which is not supported on nios2. In menuconfig of busybox, disable shared libbb. It is critical to have the right configs. Those posts were old. Please follow the new one, http://forum.niosforum.com/forum/index.php?showtopic=3174 (http://forum.niosforum.com/forum/index.php?showtopic=3174) There is a new build script, and it should be easier than ever. Hippo - Altera_Forum
Hi, hippo,
Finally got it working. Thanks for the help! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/laugh.gif --- Quote Start --- originally posted by hippo@Feb 9 2006, 01:15 AM hi bdu,it try to build shared libbb, which is not supported on nios2.
in menuconfig of busybox, disable shared libbb.
it is critical to have the right configs.
those posts were old. please follow the new one,
there is a new build script, and it should be easier than ever.
hippo
<div align='right'><{post_snapback}> (index.php?act=findpost&pid=12651)
--- quote end ---
--- Quote End ---
