21 years agostarting the cyclone development kit of Altera!
I'm a student and I really want to implement some projects whith the development kit of altera... I bought a Cyclone Development kit , with serial number SN# 05803 .Then I followed the instr...
21 years agoYou need to tell us which cable you are using, and indeed which OS. The instructions for ByteBlaster and USB-Blaster are different.
For ByteBlaster (MV or II) on Windows you need to run `jtagconfig --add ByteBlaster lpt1` on the command line. For USB-Blaster on Windows it should just work. Linux is more complex. ps. You should probably be using the IDE rather than nios-run (which is part of the legacy SDK - the old way of doing things). Once you have something working on the IDE then there are command line alternative ways of using it.
