21 years agostarter,want help!
hello,every body.
sorry for my poor english,my first language is not englsh.i began to learn niosII about two weeks ago,and i want to design a fpga which contains a soft cpu core to replace MCU(MCS-51,e.g.8031).The c code of the 8031 are partly as follows:# include <reg51.h># include <intrins.h># include <absacc.h> long i,j; sbit p10=P1^0; sbit p11=P1^1; sbit p12=P1^2; sbit p14=P1^4; sbit p15=P1^5; sbit p13=P1^3; ........ ........ ........ main() { InitializeA(); TMOD=0x20; TL1=0xfd;TH1=0xfd; PCON=0x00; TR1=1; p11=0; p11=1 xx=0; while(1) { p11=1; //delay(20); p11=0; //delay(20); p11=1; p12=0; p13=1; p10=0; p10=1; i=0; p15=1; xx=p15; while (xx==0) { p15=1; xx=p15; } p15=1; xx=p15; if(xx==1) p11=0; p11=1; p12=1; for(i=0;i<286;i++) {//for1 for(j=0;j<360;j++)//720 { //for2 P0=0xff; re_am=P0; if(j<359) //718 359 { SBUF=re_am; while(TI==0) { } TI=0; //delay(5); } P2=0xff; re_am=P2; if(j<359)//359 { SBUF=re_am; while(TI==0) { } TI=0; //delay(5); } p13=0;p13=1; } //for2 } //for1 }//if_end }//first while_end } i want to write this code into niosII,and use the cpu soft core to achieve the fuctions play by the MCU. as show above,MCU uses p10...p17 as control signals,how can i achieve this in nios?can i use PI/Os to replay p10...p17 to play control fuctions?if it does,how can i link the p10...p17 to the PI/Os in c code? and SBUF in MCU is a serial port,can i use UART to replace it?and the examples altera provides always use UART to transfer charicters,then how can i use it to transfer control signals,as 0,1? i think the function i want to achieve is not difficult,but i am a poor starter,and i have been confused with it for a long time .can you help me with it ,kind persons?1 Reply
I think you should look at the documentation, which can be found in the altera\kits\nios2\documents directory, probably starting with n2cpu_nii5v1.pdf and n2sw_nii5v2.pdf.
After that if you launch the Nios II IDE, you'll find lots of helpful tutorials.
