17 years agoStart Module on uClinux Boot
Hi all,
I would want my module to start on uClinux Boot ( without using modprobe after booting the kernel). I tried doing what said on the wiki ( module programing (http://www.nioswiki.com/operatingsystems/uclinux/moduleprogramming)) Device Drivers --> Misc devices ---> <*> example hello module but when uclinux boot, the module starts before other processes start like ethernet connection (as example, this conifg come after the module starts : ifconfig eth0 255.xxx.xxx.xxx), so the module isn't starting correctly. to make my self clear, My module uses socktes and without starting ethernet connection the module won't work. how should i delay the module booting so it will start after establishing a connection ? Thanks, Erez1 Reply
no one ? well it seems that if you want the module to be part of your kernel, it needs to upload the module prior uploading the configuration file with the connection settings ( i.e the rc file in vendors->nios2), so again my module isn't starting correctly. is there no hope for that issue? Erez
