11 years ago
start linux failed(fdt_initrd)
Hi, I have met a problem that the soc stopped at starting kernel ......
here is my message
U-Boot SPL 2013.01.01 (Jul 09 2015 - 09:16:54)
BOARD : Altera SOCFPGA Cyclone V Board
CLOCK: EOSC1 clock 25000 KHz
CLOCK: EOSC2 clock 25000 KHz
CLOCK: F2S_SDR_REF clock 0 KHz
CLOCK: F2S_PER_REF clock 0 KHz
CLOCK: MPU clock 800 MHz
CLOCK: DDR clock 400 MHz
CLOCK: UART clock 100000 KHz
CLOCK: MMC clock 50000 KHz
CLOCK: QSPI clock 400000 KHz
INFO : Watchdog enabled
SDRAM: Initializing MMR registers
SDRAM: Calibrating PHY
SEQ.C: Preparing to start memory calibration
SEQ.C: CALIBRATION PASSED
SDRAM: 512 MiB
ALTERA DWMMC: 0
U-Boot 2013.01.01 (Jul 09 2015 - 09:20:51)
CPU : Altera SOCFPGA Platform
I2C: ready
DRAM: 512 MiB
MMC: ALTERA DWMMC: 0
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Skipped ethaddr assignment due to invalid EMAC address in EEPROM
Net: mii0
Warning: failed to set MAC address
Hit any key to stop autoboot: 0
reading u-boot.scr
** Unable to read file u-boot.scr **
Optional boot script not found. Continuing to boot normally
reading zImage
Invalid FAT entry
3194880 bytes read in 341 ms (8.9 MiB/s)
reading socfpga.dtb
20633 bytes read in 7 ms (2.8 MiB/s)# # Flattened Device Tree blob at 00000100
Booting using the fdt blob at 0x00000100
Loading Device Tree to 03ff7000, end 03fff098 ... OK
WARNING: could not create /chosen FDT_ERR_BADSTRUCTURE.
WARNING: could not create /memory: FDT_ERR_BADSTRUCTURE.
fdt_initrd: FDT_ERR_BADSTRUCTURE
Starting kernel ...
it seems there is something wrong with the fdt, but i know little about linux,
dose anyone have met the similar problem or can help me
thanks
