12 years agoStandard Ethernet example cpu generation issue
Hi, I am trying to regenerate the standard ethernet design useing quartus webpack 12.0 sp2 and I get the following errors when I generate the niosii-ethernet-standard-3c25/eth_std_main_system in Q...
12 years ago --- Quote Start --- Hi, I am trying to regenerate the standard ethernet design useing quartus webpack 12.0 sp2 and I get the following errors when I generate the niosii-ethernet-standard-3c25/eth_std_main_system in Qsys. What am I doing wrong? Error: cpu: Failed to generate module eth_std_main_system_cpu Info: cpu: Done RTL generation for module 'eth_std_main_system_cpu' Info: cpu: "eth_std_main_system" instantiated altera_nios2_qsys "cpu" Error: Generation stopped, 74 or more modules remaining Info: eth_std_main_system: Done eth_std_main_system" with 36 modules, 16 files, 949361 bytes Error: ip-generate failed with exit code 1: 2 Errors, 7 Warnings Info: Finished: Create HDL design files for synthesis --- Quote End --- Found that generate doesn't work when using Quartus as an operating system
