20 years agoStand alone lwIP
Hi all,
I downloaded and installed the stand alone lwIP from the 'Tested IP'. There is a code named 'lan91c111if.c' and I tried to understand line by line of the code. In the function low_level_input(struct netif *netif), there is a line like below, buf = dev->ethernet_dev_list.dev.read_routine(dev, if_getbuf); --- A It seems like, but I'm not sure that 'if_getbuf()' is called by 'read_routine', but I coudn't find any line which shows that read_routine() calles 'if_getbuf()'. There is only a structure defined in 'alt_ethernet_dev.h' as follows, struct alt_ethernet_dev { void* network; const char* name; int (*init_routine)(); /* low level initialization */ void (*rx_routine)(); /* low level device service */ void* (*read_routine)(); /* low level input */ --- B int (*write_routine)(); /* low level output */ }; It is just a function pointer[void* (*read_routine)()] right? But I coundn't find any assignment for this pointer to point a function. I mean I don't understand the relationship between line ---A and ---B. How is the function 'if_getbuf()' called? Thank you.No RepliesBe the first to reply
