22 years agostand-alone Leightweight IP Package
Hi all,
when will the stand-alone Leightweight IP Package be available? Will it run on NIOS I or on NIOS II?5 Replies
Hello mschulz,
I don’t know when the package will be available but I think it will only be for the Nios II because for the Nios I you can take the ready PLUGS Library. Bye, niosIIuser - Altera_Forum
Hi niosIIuser,
the PLUGS is a library but not a complete stack (e.g. no windowing, no wait for ACK, ...) as the lwip is. So if mschulz needs a stack PLUGS is not a choice. It would be very helpful if the stand-alone lwip would also work together with NiosI. Regards, damc - Altera_Forum
Hello damc,
Thank you for that explanation. I would like to have the stand-alone lwip package also because I don’t want to use the MicroC/OS-II for the Nios II. Bye, niosIIuser - Altera_Forum
Hi niosIIuser,
right, but why should this stand-alone version only work together with NiosII? Shouldn't it be simple C?!?!? Bye, damc - Altera_Forum
Hello damc,
The provided lwip from Altera in the Nios II IDE isn’t a stand-alone version. It can only be used with the OS from Micrium. Of course it is only C but by knowledge about C and lwip is not enough to separate the lwip from the OS. That’s why I hope that the stand-alone lwip version for the Nios II will be released soon. Bye, niosIIuser
