21 years agostack problem (printf?)
I have some problems with a custom board and software.
It seams that the stack get's destroyed, when I use the printf function. I don't know if printf is really the problem. Always if i change something, it works or it works not ! I could not produce the error on the cyclone dev. board. I could reduce my software to a small testprogram, which fills a testbuffer (srcbuff) in global memory, copies it then onto the stack (dstbuff) , calls printf and compares afterwards the two buffers. some system properties: - quartus 5.0 Nios 5.0 - NiosII/s (2k instruction cache) - 1k onchip memory (exception address 0x00000020) - external sram 0x800000-0x87FFFF - reduced device drivers (jtag uart should use no interrupt) - no os the following testprogram works if - dstbuff is global (not on stack) or - printf is used (but interrupts are disabled during call to printf) or - printf is replaced by iprintf or - printf No.2 is used instead of printf No.1 if the program is like below, dstbuff is on stack,interrupts are enabled, then i get error e.g. ... Hello from Nios II! TESTCOUNT:00000 +++ ERROR dstbuff first diff index :32764 at 0x00814008 srcbuff:60 first diff index :32764 at 0x0087FFE0 dstbuff:E4 ... # include <stdio.h># include <stdlib.h># include <string.h># include <time.h># include <alt_types.h># include <unistd.h># include "sys/alt_irq.h"# include"system.h" # define BYTE unsigned char # define BUFFSIZE 32768 BYTE srcbuff[BUFFSIZE]; // BYTE dstbuff[BUFFSIZE]; int fill_testbuffer(BYTE *buffer,int count); alt_irq_context irqcontext; int main() { BYTE dstbuff[BUFFSIZE]; int testcount=0; int i; printf("Hello from Nios II!\n"); // irqcontext=alt_irq_disable_all(); while(1) { fill_testbuffer(srcbuff,BUFFSIZE); memcpy(dstbuff,srcbuff,BUFFSIZE); // irqcontext=alt_irq_disable_all(); printf("TESTCOUNT:%05d\r\n",testcount++); // PRINTF No.1 // printf("CLOCK:%06d TESTCOUNT:%05d\r\n",(int)clock(),testcount++); // PRINTF No.2 // alt_irq_enable_all(irqcontext); if(memcmp(srcbuff,dstbuff,BUFFSIZE)) { for(i=0;i<BUFFSIZE;i++) { if(srcbuff!=dstbuff) { printf("+++ ERROR dstbuff\r\n"); printf("first diff index :%d at 0x%08X srcbuff:%02X\r\n",i,(int)&srcbuff,srcbuff); printf("first diff index :%d at 0x%08X dstbuff:%02X\r\n",i,(int)&dstbuff,dstbuff); break; } } while(1); } } return 0; } int fill_testbuffer(BYTE *buffer,int count) { int i; unsigned int seed; seed=clock(); srand(seed); for(i=0;i<count;i++) { buffer[i]=rand(); } return 0; } any ideas ? thanksNo RepliesBe the first to reply
