20 years agosshd on Nios II uClinux with buildroot
Hello tschmelcher,
I am following your defined step for sshd on Nios II. http://forum.niosforum.com/forum/index.php?showtopic=3252 (http://forum.niosforum.com/forum/index.php?showtopic=3252) Step 1 works fine. Step 2 have some problems 1.) Make its config.h.in: autoheader I didn't get exactly. 2.) while configuring with given command, it failed with given below error message. it is looking for zlib. ******configure: error: *** zlib missing - please install first or check config.log *** 3.) I did make in usr/ssh dir. in the start only following message came. what to do? ********************************** (cd openbsd-compat && make) make[1]: Entering directory `/home/goutam/uClinux-dist-test/user/ssh/openbsd-compat' cc -I. -I.. -c -o bsd-arc4random.o bsd-arc4random.c In file included from ../includes.h:22, from bsd-arc4random.c:25: ../config.h:9:29: config/autoconf.h: No such file or directory make[1]: *** [bsd-arc4random.o] Error 1 make[1]: Leaving directory `/home/goutam/uClinux-dist-test/user/ssh/openbsd-compat' make: *** [subdirs] Error 2 **************************************** How the error will remove. is any more patches required? thanks & regard, Goutam2 Replies
may be you should try uClinux-dist-20051110 in step2.
I built the ssh and sshd with buidlroot and uClinux-dist-20051110.
But I didn't run them yet. (I don't have any boards with Ethernet) 1. follow tschmelcher's sshd guide, build openssl in buildroot. 2. build zlib in buildroot, it may fail in so, but just ignore it. 3. apply the uClinux-dist.diff as in build script. edit uClinux-dist/vendors/Altera/nios2nommu/config.arch, add "-lcrypt -lutil" to LDPATH for apps. touch uClinux-dist/vendors/Altera/nios2nommu/inittab 4. build ssh and sshd in uClinux-dist, but DON'T use the cross patches in tschmelcher's sshd guide. make menuconfig,make subdirs,make romfs.
