17 years agoSSH broken
Under Customize Application/Library Settings Network Applications --> [*] ssh [*] sshd [*] ssh-keygen I also enabled syslog BusyBox --> [*] System loggi...
17 years ago<div class='quotetop'>QUOTE (hippo @ Aug 5 2009, 04:29 AM) <{post_snapback}> (index.php?act=findpost&pid=23414)</div>
--- Quote Start --- I have ds1307/ds1338 worked on NEEK. Please see the wiki, http://www.nioswiki.com/gpio (http://www.nioswiki.com/gpio)[/b] --- Quote End --- - Is there a cause why, on the NEEK hardware, bit baning on a GPIO port is implemented instead of using some I²C ipCore ? - Does this I²C interface-driver support an I²C "subsystem" so that I²C "chip driver" Kernel modules can be created that use these hardware pins as a common bus for multiple different I²C enabled chips ? -Michael
