21 years agoSRAM vs SDRAM
Hi, I am about to design a system with uClinux, and I was wondering if the performances would be correct if I only used an SDRAM. SRAM is a bit expensive if I want to have enough memory to run...
20 years agoWhat kind of power restrictions are you on? I persoally don't think DDR is too heavy on power... that is, without using Vtt termination. I doubt you could get to speeds high enough to require Vtt termination, unless you had multiple chips banked.
Maybe DDR2?
