21 years agoSRAM vs SDRAM
Hi, I am about to design a system with uClinux, and I was wondering if the performances would be correct if I only used an SDRAM. SRAM is a bit expensive if I want to have enough memory to run...
20 years ago --- Quote Start --- originally posted by smcnutt@Jan 20 2005, 01:29 PM hi cetic,
> ... i have read in some threads around here that sdram performances
> were quite bad.
i've found the sdram controller performance to be pretty awful. given
the logic area it occupies and its performance, i no longer consider it a
viable alternative for many new designs.
> sram is a bit expensive if i want to have enough memory to run
> my linux (i guess i need at least 4mb).
i've switched to psram (pseudo sram) for new designs. it eliminates
the sdram controller and it performs better[/b]. The cost is very attractive ... the expense is the number of pins you must use. Regards, --Scott <div align='right'><{post_snapback}> (index.php?act=findpost&pid=4142) --- Quote End --- [/b] --- Quote End --- Scott, I've been consdering using PSRAM for our upcoming NIOS II system, mainly due to it's much lower power consumption vs DDR. Do you use the PSRAM as a simple SRAM replacement (in which mode it has quite slow 70ns access times) or do you make use of the Burst mode to get much faster average access rates? I've been tinking about knocking up an interface block to access it in burst mode but the effectiveness of that depends on whether the NIOS can cache grabs it's instruction stream in bursts or not. Mark.
