21 years agoSRAM vs SDRAM
Hi, I am about to design a system with uClinux, and I was wondering if the performances would be correct if I only used an SDRAM. SRAM is a bit expensive if I want to have enough memory to run...
21 years agoHi cetic,
I'm using Micron MT45W4MW16PFA (4M x 16-bit), but will be switching to the MT45W2MW16PFA (2M x 16-bit) if all goes well. The marketing name for the part family is "ASYNCHRONOUS CellularRAM". > what amount of memory I need to run a linux properly ? That depends on your application's memory requirements. For my application 8 MB is plenty, but 4 MB might be a tad too tight. The two parts above are pin compatible ... so I'm not terribly concerned. You might want to do some experimenting on a development board (altera or microtronix) ... to get a better feel for your requirements. Regards, --Scott
