21 years agoSRAM vs SDRAM
Hi, I am about to design a system with uClinux, and I was wondering if the performances would be correct if I only used an SDRAM. SRAM is a bit expensive if I want to have enough memory to run...
21 years ago> Do you still have an idea whether the SRAM is used or not ?
I don't believe it's used in the kernel version I'm using. It might be mapped in mtd ... I never checked ... and I didn't see it mapped into a region in the startup either. > do I still need a SRAM if I made a custom board where Linux is > run from a SDRAM (just like on the devboard) ? No, the SRAM is not necessary -- you can run linux just fine without it. Regards, --Scott
