21 years agoSRAM vs SDRAM
Hi, I am about to design a system with uClinux, and I was wondering if the performances would be correct if I only used an SDRAM. SRAM is a bit expensive if I want to have enough memory to run...
21 years agoThanks for your reply,
that means that the system I am currently using on the Altera Cyclone devboard is very slow, I guess. Do you still have an idea whether the SRAM is used or not ? My question is do I still need a SRAM if I made a custom board where Linux is run from a SDRAM (just like on the devboard) ? Any way I will check the PSRAM solution. Thanks, cetic
