21 years agoSRAM slower then IDT71V416
If I use a SRAM component slower then the IDT71V416 (my SRAM is 15n instead of 10n) do I need to configure a new component in the SOPC builder ? If so, why no one thought of a general compone...
21 years agoJust keep jacking with the setup. The setup wizard is buggy but works.
What would be real nice would be a programmable controller. (Setup the timing registers in software - yahoo!) The new Create New Component way of doing things is a real pain getting things tweaked in. Not only do you have to do a regenerate; but you have to edit your component timing, then delete the old instance, add a new instance and not forget to redo the connections. At least with the old IUL way you just had to edit your timings and regen. Ken
