15 years agoSRAM Read/Write too slow
Hello, im using the nios development board (stratix edition) and the standard reference design delivered by altera. On the Nios i have the MicroCOs running. And in the Nios IDE (im using Nios I...
15 years agoHi,
have you already checked, what code is generated by the compiler (e.g. in the disassembly window) ? Especially in the debug version the compiler produces a lot of code. For the loop itself and the IORD_DIRECT32 access it is easily possible that 10-15 instructions are generated. So I think it is not a slow access to the sram which makes this code slow, it is the number of instructions which are generated. The release version should be faster.
