22 years agoSRAM interface timing parameters
I'm currently setting up my NIOSII system on my own board. I've done some measurements on the SRAM_nCS, SDRAM_nWE... signals. I find the timing a little bit too tight. It seems like...
22 years agoHere's what I got from one of the developers. Please tell me if it helps you solve your problem...
The default dev kit SRAM component (two IDT71V416 chips, normally appearing as 'ext_ram' in example designs) should automatically compensate for timing by adding appropriate Avalon wait states depending on the desired System Clock Frequency. Internal memories do not compensate in the same way; other external memories require their own class.ptf files to configure their timing requirements. You cannot modify the timing settings of the default component -- it does all the math for you, based on System Clock and it's class.ptf settings. There are 3 sets of settings (wait states & setup/hold times), for the following frequency ranges: {f <= 50MHz} {50MHz < f <= 100MHz} {f > 100MHz} To get different setting requires making your own component/class.ptf, or hand editing the system.ptf.
