21 years agoSRAM interface issue
Hi there, I am making a board based on the Nios Cyclone Edition 1C20 from Altera and have a question on the SRAM interface. I will be i/o limitted and as such do not want to use the Byte E...
21 years agoHi Jesse,
I am using a 16bit SRAM currently and do not have the ability to change my setup at this point. For now I simply need make things work. From slackers comments, it doesn't look like this is a difficult issue but I need someone to point me in the right direction. Do you see any issues with modifying the ptf file for the SRAM component? Where is the SRAM component located? The only componetn that I can see with reference to SRAM is the /nios2/components/altera_nios_devkit_startix_edition_sram. Is this the same component that is used for the Cyclone boards? I would assume they are the same anyway. Also how do I go about modifying the ptf file? Any help you can provide would be great. Regards Todd
