22 years agoSRAM in a custom board
Hello, I have a code that runs OK in the Nios development board. It use the SRAM in this board: IDT71V416 Now I'm trying to load the code in a custom board that contains a SRAM that is ve...
22 years agoHi people,
I have discovered what was wrong with my SRAM. The small C-code that "verified" the SRAM did read and write consecutive operations, instead of writing all the address lines with the address value and then read and check all the memory map. ( Yes I am a software engineerr http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/wink.gif The problem was that I had some address lines cut in my custom board! http://forum.niosforum.com/work2/style_emoticons/<#EMO_DIR#>/ohmy.gif Before this I tried to use the option "create an interface to user logic" of the SOPC builder (it use avalon bus) , that is a very easy solution for other memories slower than the original provided by altera. However there is an strange problem unsolved.. if I put the .rodata and .rwdata in the SRAM, then the programs "works" but the "printf()" not! i.e I can turn on a LED but I can not read any message in the console (JTAG). In any case it doesn't hang. The other posible memory combination works well. I know that it has no sense, I say it just in case it has already happened to anyone. More things.. Has anyone tried to programm a flash memory in a custom board without a NIOS2 license?? The Nios2-flash-programmer executes the Quartus 2 programmer with the .sof file "time_limited" and it hangs when it ask something to the user. (because you cannot reply to the Quartus 2 programmer) And... is it posible to programm a flash memory with a 33Mhz clock? the altera documentation says that below 50Mhz it could fail. To BadOmen: (sorry for my stupid mistake with the SRAM) " Make sure when you program the sof onto the device that it doesn't trigger a reset on the sram as well (doubtful it would tie into it unless you did that manually in the fpga design). " I have verified that NIOS 2 IDE doesn't erase the memory if the code is the same than before. Quartus2 programmer never erase it. "Do you not have enought onchip memory resources for what you are trying to do? If you're running out but have enabled all the various methods to shrink the memory footprint, then I'd start there." I have done a interactive web server with MicroC\OS-II and LWIP, so no way to reduce it to less than my maximum onboard chip memory (100kbytes)
